I just purchased a kflop and kanalog. I am going to be using this on a cnc router for wood that is on its way from China (similar to this
http://www.omni-cnc.com/products/auto_tool_changer_cnc_router/cnc_router_OR1530LATC.html but I chose to use a kflop controller instead).
I have four 1.5kw Delta drives and a vfd. The Delta drives are digital drives and offer the choice of step/direction or analog input signals (velocity mode not torque). The drives also have all the software required for the pid loop.
I am at the point where I have to decide the input signal I will feed to the drives. Either step/direction or an analog +10v/-10v.
I was wondering which method was better and why and even if there is a difference or rather a significant difference. I presume analog is more precise providing everything is well shielded as it is easier to vary the input voltage signal rather than a pulse frequency but wanted to get input from other users. Also, analog most likely gives a more fluid motion profile again due to the fact that it is easier to vary the voltage than the frequency, a the frequency variations may look like steps rather than a smooth curve, although there should be ample leeway as the frequency is most likely many times lower than the dsp oscillator clock.
The other issue I was curious about was about having two pid loops. One on the drive and one on the kflop. Is there any special precautions to take to avoid a battle between the two loops? Specially when adding feedforward velocity and other tuning parameters?
Thank you
Darren
